Is there a vent on the top of auto transmission unit?
Old Feb 25, 2015 | 03:29 PM
chazzz's Avatar
'05 MBZ C230K and '09 MBZ C350
I have a 2005 C230 with five speed automatic transmission (722.6?). There is a leaking vacuum pump (plan to replace it ASAP). The automatic transmission bell housing is covered with thin film of oil (from leaking vac pump).
I would like to clean it with degreaser spray and rinse with water hose. I am worried that the water might get into the transmission unit through the vent hole.
Is there a vent on the transmission unit?
Old Feb 25, 2015 | 04:31 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Water/degreaser won't go inside transmission if you clean the bellhousing area with water+degreaser. Transmission filler tube is in that area. Make sure the cap is there tight and the red lock-pin is engaged on that cap.
