camber "eccentric pin kit" question
Old Feb 25, 2015 | 04:30 PM
Cruel-Merc's Avatar
2009 C350
Hey folks, im looking forward to adjust my front camber as mine is bit positive, and i wanna know if i have to get a second pin kit for the caster ? Or one for the camber would be enough?
Old Feb 25, 2015 | 11:01 PM
K-Mac's Avatar
SPONSOR
Mercedes-Benz CLK 550
DO POINT OUT THAT THESE BOLTS (2 CAMBER AND 2 CASTER) ARE ONLY AVAILABLE FOR FRONT AND ARE ONE POSITION – NOT PRECISELY ADJUSTABLE!
Only allowing minimal .3 of one degree (1/8 of an inch – 3mm). To change means labour intensive disassembly each time.
While K-MAC front kit – replaces not just the bolts but each entire bush (which are the 4 front highest wearing bushes).
Along with the unique K-MAC patented design allowing precise single wrench adjustment accurately under load direct on alignment rack (with 3 times the adjustment range on W202 models).
Allowing precise (ongoing) adjustments to correctly resolve premature tire wear, steering pull – also essential if altering height, fitting wide tires/wheels, load carrying or curb knock damage.
Similar rear Camber kit (OEM – only Toe adjustment) which also includes extra Toe adjustment to compensate for the rear camber facility. Bush extraction/insertion tools supplied with both front and rear kits.
