Help! Where does this line go
Old Mar 23, 2015 | 08:52 PM
c230zaid's Avatar
2006 c230 V6
Intake manifold air flap replaced, but I'm still having problems
I recently did some work on my car (2006 c230) to replace the throttle body actuator which was broken, and after everything was put back the way it was, the car threw new codes that weren't there before. I should probably mention what was wrong and which codes I had prior to the changing of the part; the car used to idle poorly and shake excessively, every time I drove the car, severe sadness would over take me, sometimes it would turn off when I try to reverse... It was showing these codes: p0300, p0301, p0302, p0303, p0305, p0607, p2004. After I replaced the part, it's now throwing p0023 and also p2237 & p2240 pending I know that the two p22xx are O2 sensors which is weird because I just replaced the two sensors before the CAT about 6 weeks ago. I'm not sure if these codes are at all related to the work I just did on the car, but I don't think that it's just a coincidence ((coincidence... I don't think so)) anyways, I'm more concerned with the first code which is p0023 (camshaft related it seems) and the car still shakes when in park, not nearly as bad as before though. I appreciate any help you guys can offer. Thanks.
Old Aug 30, 2023 | 02:46 PM
tfwaok's Avatar
E-420
I was hoping someone had replied to your issue, since I have something similar going on. Wondering if this was ever resolved all those years ago???
Old Sep 3, 2023 | 11:51 AM
dbclc123's Avatar
2009 clc 180 kompressor auto
Originally Posted by tfwaok;[url=tel:8839061
8839061[/url]]I was hoping someone had replied to your issue, since I have something similar going on. Wondering if this was ever resolved all those years ago???
Have you had your throttle body off?
I took mine off to clean as it was cakes in oily crud. Car went into limp mode and threw up a load of codes. Forgot to let the throttle "reset". Turn key to position 2 then leave for about 2 minutes you can hear it doing it's thing. Then start. Solved my issue.
