Help!!! W203 Intermittent Hesitation
Old Mar 27, 2015 | 12:03 PM
yazanh82's Avatar
2006 W203 C200k
Post Help!!! W203 Intermittent Hesitation
My 2006 W203 with m271 engine is acting weird lately, the car is hesitating when accelerating from a stop. I took the car to two mechanics to check for fault codes and every time its gives the same fault (air pressure is to too low). They checked for vacuum leaks and didn't find any. Below are the things that I've changed:
Spark plugs, intake air flap actuator, air flow sensor, camshaft sensors, air filter, fuel filter, cleaned the throttle body, cleaned the catalytic converter, found some oil in the ecu plugs and cleaned it.
When I start the car in the morning it makes a loud whining noise for 10 seconds, it runs perfectly until i turn it off and then start the car again then it starts to hesitate. It runs perfectly every time I go the mechanic then one day later it starts to hesitate.
What could be the problem? The car has done 47k miles only!!
Someone told me the supercharger may be failing but im suspecting the coils!
Please help
Old Mar 27, 2015 | 01:57 PM
samaritrey's Avatar
Super Moderator
THE C350
Can you give us the fault code?
Old Mar 27, 2015 | 04:45 PM
yazanh82's Avatar
2006 W203 C200k
the fault code is p0410 (air flow is too low)
and p0120
Old Mar 27, 2015 | 05:20 PM
pcy's Avatar
pcy
'14 ML350, '13 C220 CDI, '07 C280, '98 ML320
Please help
I'd focus the investigation on the secondary air pump and related hoses/valves. Either the pump is failing and not pumping enough air or there is some obstruction in the secondary air system. The diagnostic code you've listed is related to secondary air system.
Old Mar 27, 2015 | 05:35 PM
yazanh82's Avatar
2006 W203 C200k
thanks for your reply, can you please tell me where is the pump located and as for code p0120 could it be a bad tps?? does it fail at this low mileage??
