Weak Air Conditioner
Besides the airconditioner Im quite impressed with this car
PS I live in a warm climate,
your comments would be most appreciated
Try this, run the AC with the center dashtop vent closed (if applicable) and turn off the auto mode until the interior temp is comfortable. Once the int. temp is good, then set it back to auto and you should be comfortable. Run it in REC mode(recirculate) for the highest volume of air flow. You won't blow frost out of the vents, but this should do the trick....
Also, EC mode is really only meant to be used on long highway cruises....turns off the compressor (EConomy mode) to improve gas mileage.
Our E-class works the same way, but has the digital controls that monitor the temp through multiple sensors (the C only has the one sensor on the console controls)
