ATF 134 or ATF 3353
Here is the 3353 spec sheet :- http://www.generaloils.net/PI_TITAN-ATF-3353_e.pdf
I would drain out put the correct oil in.
Do more research & obtain another opinion.
but this guide is useful if you are doing lots of maintenance yourself.
page 20 has transmission fluids.
then use the BEVO link from above post to find list of approved products..
Is it shifting OK etc? If not take it back to the mechanic.
ATF134 is the newer spec 236.14, but many swear by the older spec.
236.12
Back in the day, they had one fluid for the 5 speed and another for the 7 speed, now
ATF 134 is used for both.
Personally when switching specs I like to do a full flush.
Not sure if it matters if you mix the 2.
The dealer will tell you to use 134. It's all they sell and supercedes the older fluid,
but like I said, it's still ok. I think it's a little thicker viscosity I read somewhere.
Some people won't use the newer fluid in the 5 speed.
I run it. works fine.
