Cruise Control
Cruise Control
Hello everyone , I have a w203 , ( c200 2003) the cruise control does not work , the lever no signs of life , the instruments nothing error esp or other error, the star diagnosis not by any error .
can you help me? the lever nothing works.
thanks!
thanks!
2003 C230K Coupe Orion Blue
Check the fuse first. If that's fine, try replacing the switch. Might've gone bad. There's a DIY for it in this forum.
I assume you're driving a sedan.
Pull out the fuse map, tucked inside a piece of paper in the car. It's behind a side panel where the dash meets the driver's side door. Interesting enough, I don't see anything specific to the cruise control.
A bit of a wild guess, but I would start with the ones below.
Instrument cluster 42
Engine electronics 48, 53, 54
Pull out a the fuse map, tucked inside a piece of paper in the car. It's on a side panel where the dash meets the driver's side door. Interesting enough, I don't see anything specific to the cruise control.
SPONSOR
The C200 is similar to a C320 here in the states. This tech article may be able to help, not 100% sure, assist you in replacing the stock if that is what you plan on doing.
-Luccia
-Luccia
