Light turning das activating
Old Apr 18, 2015 | 08:40 AM
rubenalf's Avatar
w203
Hello everyone I tried to turn on the lights turning from das in developer mode , unfortunately I did not succeed , there is no comfort in the menu item for turning light and activation encoding does not work , if anyone knows the procedure ( from das ) .
thanks
Old Apr 18, 2015 | 04:17 PM
samaritrey's Avatar
Super Moderator
THE C350
Are you trying to turn on the fog lights to come on when turning? Are you sure the W203 can do that I don't remember ever that option only on the w211. Also what year is your car as if it was available only newer ones might have it. I did it on my w211 I think it was under front sam but if you search under the w211 section you should be able to find the directions and it might give you a clue on where it would be on the w203.
Old Apr 18, 2015 | 10:30 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
It is possible on facelift w203s. Not sure about pre-facelift.
This thread might help: https://mbworld.org/forums/c-class-w...n-feature.html
Although I remember there being a setting in English (i.e. Not in developer mode)...
