Tools needed for C32 AMG brake install???
2015 E250D
I plan to install the c32 brakes in my car but wanted to know what tools I need. I have a bleeder set, all metric wrenches and sockets. Anything else I need? Also, I have to order the brake pad sensors. Are they same as the c320?
C230Kompressor
Re: Tools needed for C32 AMG brake install???
One of my set screws was stuck so I had to use the breaker, the other came out fine.
The sensors should be the same-you only need one.
Get some extra brake fluid & some kitty litter. Everything is easy to get to, so if you have two people, you don't even need a bleeder kit. I got mine firmer by hand than the dealership did with their fancy machine.
2015 E250D
I already have the torx sockets. Do I need any hex bits? Also, what size torx drivers do I need. I have a bit set up to t40. I may go ahead and buy the torx bit sockets. Already have the breaker bar as well.
C230Kompressor
