Windshield Washer Fluid Bottle
Old Jan 24, 2004 | 12:21 PM
EDC320's Avatar
2015 ML350 4Matic
Anyone else have this problem:
The windshield washer fluid bottle (filler neck portion) is attached with one screw. - The plastic area into which the screw is inserted has split in 3 and thereby allows the neck of the bottle to float freely in its immediate area. Sooner or later this will interfere with a vital moving part in the engine compartment.
Any ideas on how to fix / replace this part?
Should it be under warranty?
Thanks for your help!
Old Jan 24, 2004 | 01:32 PM
Lynn's Avatar
It is covered by the warranty. I haven't had this problem, but others have.
Old Jan 24, 2004 | 04:30 PM
EDC320's Avatar
2015 ML350 4Matic
I guess I'll wait for my next sevice.
Old Jan 24, 2004 | 04:31 PM
Narcissus's Avatar
2001 C240 Tectite
It is covered
By warranty, I had the same problem although I am over 50,000 miles, they were to charge me 110$ CAN to fix so I just used tie-wraps and fixed it myself, the plastic looks really cheap and a friend of mine had the same problem on his 230 coupe, seems the cold/hot weather change causes this problem
