Need a qualified eletronic technical for ECU Cluster and Airbag module Service C320
Old Jun 12, 2015 | 04:57 PM
leopoldorbm's Avatar
c320/2001
Question Need a qualified eletronic technical for ECU Cluster and Airbag module Service C320
I need a qualified eletronic technical for ECU, Cluster and Airbag module Service in my c320 2001 w203.064
My ecu got wet some time ago and now is starting to give me problems, so I need to clone my ECU to a perfect used conditions one part number is A0305455832
I also got problem in my cluster that was stolen, so I need to reprogram a used one from other car to reconize the odometer (I already bought one)
My car come from an accident before my purchase so I also need to erase cash datas
Can you help me out with those problems? How much you charge for this job?
DOES ANYONE can advice me who can do this kind of service?
Thank you
Old Jun 14, 2015 | 09:04 PM
samaritrey's Avatar
Super Moderator
THE C350
You need a different car wow so many problems
Well to swap ECU you will need to get someone to desolderer the eprom chip that holds the vin and other coding for your car and swap it into the used ECU.
For the cluster since it was stolen (who steals w203 clusters they are worthless?) If you had it you could use the used cluster and do the same thing you do for the ECU but since it is gone you will need to buy a new one from Mercedes as once they go over a certain millage they can no longer be reprogrammed (something like 100 or 1000 miles.) That said I have heard of hacking them using questionable software/products.
Erase crash data? Don't understand this one if you are getting SRS lights and stuff like that once you replace the parts you can clear them with a mercedes diagnostic computer.
I don't know much about your country pricing but in the USA this would be a few thousand dollars for parts and labor. I recently sold my 01 c320 with 215k miles on it for $3,500 (guy overpaid by probably 1,000 or more) so doing that many repairs on my car would have been crazy... how much is the car worth in your country?
