Price of spring install?
Old Jan 30, 2004 | 10:38 PM
Gump's Avatar
2004 C240/ 2000 Civic Si
Originally posted by s4iscool
The W203 has an annoying rear spring setup, where you have to gain access to the strut tops through the trunk.
That's a fairly common setup, most Honda's/Acura's are setup that way.
If you are knowledgable with cars, then IMO you should do it yourself.
Old Jan 30, 2004 | 10:51 PM
beatgarden's Avatar
did it myself ...for freeeeee its not that hard
Old Jan 31, 2004 | 02:11 AM
Blake P's Avatar
'09 A4 S Line
not.at.all.
Any "do-it-yourselfers" in the bay area want to do the install for me for a low low price?
Old Jan 31, 2004 | 04:11 AM
Benzino's Avatar
03 c230
yeah the same people that cut my spring.. is there a difference between installing a spring and cutting one? please let me know whats the difference is? and s4iscool i dont recall opening your trunk to gain access to the spring? it is quit easy to do if you have the proper tools..
Old Jan 31, 2004 | 09:47 AM
s4iscool's Avatar
Do a search on google for "bad cutting springs" Mainly you are destroying the designed sping rate, and if they are progressive in nature, you are wacking away coils that make that very spring "progressive" This will screw up your handling as well as the ride...boing boing...it can be very dangerous as well if that spring snaps from the added pressure.
I doubt the c32 is different, but you have to open the trunk and pull the lining out to access the stut tops. I cant seee how you could remove them if you dont get access from the trunk.
Also, i would never let a shop touch my car for suspension install if they were the ones that advocate and actually cut coils off customer cars.
Old Jan 31, 2004 | 11:22 AM
beatgarden's Avatar
the rear springs can be taken out from the bottom without going through the trunk ... the rear springs sit in a cuplike thing and is not sitting on the strut.. i took mine out without going through the trunk .. the front is different ..as the front sits with the strut ..correct me if im wrong ..
Old Jan 31, 2004 | 11:27 AM
  #32
jo17jC230's Avatar
2008 C300 Sport
you're correct... you dont need to go through the trunk to take out just the springs...
Old Jan 31, 2004 | 11:42 AM
  #33
vadim's Avatar
'19 GLC 300, '19 TM3SR+
Being able to do it yourself is one thing, having all necessary equipment - another. I have done all my mods myself, but I can't possibly change springs on my driveway (which is not level, on top of everything).
Old Feb 2, 2004 | 12:17 PM
  #34
tommywommy's Avatar
freakin spring install cost me 500 bucks. damn freakin pittsburgh ****'s...
