c200 brake switch or neutral safety switch
Old Aug 13, 2015 | 07:52 PM
willbro's Avatar
clk230, c200
Hello all,
we bought a 2002 c200 which started and ran well when we viewed it, after one day of use the break lining wear alert appeared. After the car was parked it refused to start again until I locked and unlocked it a few times then it did. Now the car will not start and is also stuck in park,, we managed to unlock it from park and push it to the side of the road. We have bought a brake light switch but yet to find where to put it, we appreciate any pointers. Neutral safety switch could be another option
Old Aug 15, 2015 | 05:25 PM
Alswag's Avatar
2003 CL203 C320, 2002 W208 CLK320 cabriolet, 2012 A207 E350 cabriolet, 2011 X204 GLK350 4matic
Might need one of the gurus, but it could be an electrical fault. Check the battery voltage as sometimes a faulty battery will cause a whole heap of problems, especially if the car has sat for a while.
OR it could be a problem with the front SAM module. Engine electronics AND transmission electronics both have fuses in the from SAM. Check fuses and your battery. Doesn't sound too expensive, thank goodness.
