2006 C280 Luxury Transmission Fluid Change
Old Aug 24, 2015 | 06:06 PM
MAppleton's Avatar
2006 Mercedes C280 Luxury
Angry 2006 C280 Luxury Transmission Fluid Change
There I was, all set to change the transmission fluid after combing forums, youtube, and the repair manual for the car for method. I determined the car would probably have the sealed transmission fill port that requires you to remove the red locking pin and use a dipstick tool to check fluid level. So I removed the air filter housing off the engine and I could not locate any such fill port in the engine compartment. However I found a "childproof" cap on top of the transmission. Please help me complete my fluid change. I have all the tools I need and have no desire to take it to the stealership.
Note: this is a 7 speed transmission
Attached are images of where the sealed trans fluid cap should be and the childproof cap
No fill cap
Old Aug 25, 2015 | 11:13 AM
MAppleton's Avatar
I searched online and confirmed with MB I have a 722.9. I think I will go ahead and do the fluid change given information on other threads and forums. I might just get the hotdog as well! Thanks for your response.
Old Jun 23, 2022 | 10:54 PM
ART005's Avatar
2006 C280
Thank you so much for the photo. I couldn't have taken better myself. I did manage to pry off the orangish oval plastic cap a little to the passenger side of the black cap that you featured. We have a leak that is likely trans fluid since engine oil and coolant are not leaking. Maybe it's the elec connection into the transmission. Haven't been underneath yet to learn more. Wanted to just pour in a few ounces of fluid while waiting for the dip stick and then the whole day changed when access to the tranny fluid change as is the theme of this thread. Can I just pour ATF into the opening where I pried off the orange oval plastic cap?
