Bad battery, EIS, or key?
Old Sep 4, 2015 | 05:35 PM
FreshVibes's Avatar
C240
Hey guys,
I've recently been having a number of issues with my 02' c240, sadly.. Yesterday morning I went to the gym and the car was running fine. Left the gym and it was totally fine. Had to go in for a meeting at work later that morning and I was unable to turn the key in the ignition. I had a cousin of mine who's a mechanic come over and he said it was the key. So I took his word for it and the car has been sitting since then and I planned on going to the dealer today once my dad had the time to take me. I've been reading here and there trying to really find out if it really is the key and not the EIS (hopefully not..) but I had this weird feeling that it might not be either of those. I went to check on the car and I noticed when I opened the door, the screen on the cluster is on as it should be, but after a few seconds the miles go away and it shows "------". I turned on the headlights walked up front and noticed they started flickering. So maybe it's the battery? The dome lights and reading lights will turn on fine, but once I turn on the headlights and fogs, they begin to dim and start flickering then eventually cut out as with the headlights. I will be having my cousin come over and check the voltage on the battery here in about an hour so hopefully it's just the battery? Should be the reason why the EIS isn't reading the key because it doesn't have power, correct? Also, recently if my car sat overnight it would have a hard time starting.
Hope you guys can help! thanks in advance!
Old Sep 4, 2015 | 06:13 PM
EuroDriverSD's Avatar
2016 E350 Sport; Mom Wrecked the 2008 E350; sold the 2002 C320
Very strong possibility it's just the battery - take it to a parts store (autozone, pep boys, o'reilly, etc), they will check it for free
Old Sep 4, 2015 | 06:35 PM
FreshVibes's Avatar
C240
Thanks Euro! I had my cousin check the voltage and it was only putting out 9. He took the battery home to charge it to see if it would start/let the key turn after it's been charged. I'm just wondering how I managed to turn on the car these past few weeks. Maybe this San Diego heat has been giving the battery enough power lol. Fingers crossed all things will go well. Maybe the battery could have been a culprit to the radio/d2b issue? Maybe I'm just wishing for too much lol. I just want the car to start and not have it be a replacement key or EIS..
Old Sep 4, 2015 | 06:59 PM
I can almost bet you that replacing the battery will fix all of your problems. Now the question is, whether it's the battery or the alternator.
If your cousin hasn't taken the battery yet, turn on the car and with the engine running, check the voltage again. If it's below 13.5 - 14 volts, then it's the alternator. It could also be both, although less likely.
Old Sep 4, 2015 | 07:45 PM
FreshVibes's Avatar
C240
The battery was only putting out 9 volts. He took it home to charge it to see if it's the battery which is causing the EIS not to recognize the key. I recall having the alternator changed about 4 years ago. Do you remember when we had that huge power outage in San Diego, Euro? The alternator went out the same day which is really ironic lol.
Old Sep 4, 2015 | 08:09 PM
That's funny, that it went out that same day. My brother in law works for SDG&E and even they could not get a reasonable explanation that day as to what happened.
So the question for you is whether your battery has 9 volts because the cells went bad, or because the alternator is not charging it. As soon as you put it back in the car, I suggest you check the voltage with the engine running. It should give you roughly around 13.5 - 14 volts. Any less than that and I would declare it dead.
Where did you buy your replacement alternator? I bought my C320 about a month ago. I had only had it a week when I got the warning that is was not charging. The alternator looked almost new and sure enough, it was from Autozone - didn't surprise me at all, since I have had many issues with rebuilt alternators, starters and other electronic components from them. Any rebuilt electrical stuff from Autozone, Pep Boys, etc., is worthless - best to buy new. O'Reilly & Napa are a little better but I still don't trust them. In my case, my brother had been junk yard diving when I called him about my alternator. He found me one off a C240 that has been running just fine.
Old Sep 4, 2015 | 09:10 PM
FreshVibes's Avatar
C240
My cousin had the alternator ordered when he was workin at AJUSA in Mira Mesa at the time. I'm not too sure where he ordered it from though. Hopefully the battery fixes the issue. I'm keeping my fingers crossed.
Update -- got the battery charged up and the car started right up. I forgot to have the battery voltage checked when running, but he did say the alternator is fine. Hopefully the battery just went completely bad because he said the battery is probably really cheap since he's never seen the brand before. Someone must've really cheaped out on a new battery (my dad.. Filipinos..). I'm just wondering what could have really drained the battery that bad to have it only be putting out 9 volts. Either I left something on, but it would have had to be something big. Maybe the battery just called it quits?.. Hopefully the car fires up fine tomorrow so I can go out and buy a new battery and also check out a car I'm trying to pick up. Do you guys have any good recommendations to where I should buy a battery? My cousin told me to just get it from the dealer but I wonder how much that'll cost.
Old Feb 19, 2018 | 04:21 PM
blakeomlie's Avatar
ML350 2011
new key fob battery still not recognized on dashboard?
i did check it at the following/fine but often have to close/open doors then i can start car? blakeomlie@gmail.com
Old Mar 7, 2018 | 08:03 PM
kenbefound's Avatar
2014 Sonata 2.0T
I saw a video on YouTube where the door handles on the C43 were illuminated, is this standard or part of the LED or Advanced Lighting Package? Also, does the Advanced Lighting Package include a proximity feature where the car will light up at night as you approach it?
Old Mar 10, 2018 | 07:55 AM
Jay11's Avatar
2003 Benz C240
Get an AGM from Amazon it's $199 free shipped. I got mine from Wally $120 something I think, because I not sure how long I will keep the car. It's an Evermaxx, made in Germany. Last one in my BWM lasted from 2011 to now. So I am ok with them.
Old Mar 10, 2018 | 03:54 PM
blakeomlie's Avatar
ML350 2011
I did check fob battery key at O’Reilly’s and it was fine but dashboard still says key not recognized replace battery; it opens door and usually enables car to start but sometimes i need to unlock doors while in car to start; any others having this issue and know a cheap fix? Dealer says get new key fob for $200-nope!
Old Mar 10, 2018 | 06:51 PM
Jay11's Avatar
2003 Benz C240
With you on the nope.
I remember being advised to factory reset but my issue solved before I had to do that. Someone else with more experience can advise further if this would be helpful.
Old Apr 10, 2018 | 03:18 PM
Songbird58's Avatar
2006 ML350
Sunroof, tailgate, blinkers, sunroof, gas gauge dont work & car won't start.
Have a 2006 ML 350 SUV. Sunroof stopped working, then tailgate wouldn't open, then blinkers stopped working, then gas gauge & clock went haywire. Clock was turning backwards when I put key in, then car wouldn't start. Now car won't start
Old Apr 10, 2018 | 03:42 PM
Songbird58's Avatar
2006 ML350
