Subframe Drop
Old Sep 19, 2015 | 01:56 PM
Nelson Costa's Avatar
2002 mercedes c240
Subframe Drop
Hi everyone
I just have a simple question that i cant seem to find answer and DYI tutorial. I am want to change my rear camber i just dont know if i have to drop the subframe in order to change them. or its just bolt in bolt out.
Thank you
Old Jan 29, 2022 | 11:05 PM
bkdc's Avatar
2015 S550, 2017 GLS450
Confused about the question. Are you asking if the subframe needs to be dropped to change the control arms to install an adjustable camber kit?
The longest control arm with a slight curve which would be the most important for camber does not need a subframe drop.
the front most control arm has a bolt that cannot be removed without a subframe drop. But the solution is a few minutes with a reciprocating saw and a 9 inch long metal cutting blade to cut the bolt through the existing arm and installation of a new control arm and a new bolt inserted In the flip direction.. It takes 5 minutes and saves you hours of headache.
