Stupid question...im sure the C class owners can shed some light
Ok ive been having some debate with someone regarding rims. I have never heard this before but it appears that my friend thinks that if you go with wider tires on your car it will slow the car down considerably. Im not just talking wider tires on your stock rims im talking about going from your standard 16" rims/tire to an 18" setup, say 8.5 and 9.5. I personally think it has nothing to do with the width of the tire, just the weight of the bigger rims and tires. Can anyone clarify?
1. Slow down your accelleration - Nothing too noticeable
2. Make your speedometer inaccurate...by 1-3 MPH, nothing major.
It's not like your car is going to be as slow as a Geo Metro...you'll prob. like the look over the minimal performance drop.
Erik
The increased friction/rolling resistance will worsen fuel economy and lower top speed somewhat.
Then there is the matter of the weight of the wheel/tire combination. The heavier it is, the higher the unsprung weight, which will actually counteract the enhanced grip and make the car a handful to drive on bumpy roads.
Erik
Inertia. It takes more effort to rotate something further away
from the center axis.
From the center axis of rotation, the more cross sectional area of
material you have further out, the slower you rotate.
A well known example, ice skater pull in their hands to spin,
and stick out to slow down the spin.
it may slow it down a bit, but with c classes other than the c32 i dnt think u would even notice it/or matter.
Going from 16s-18s will:
