Matching C7 Pedals
Old Feb 10, 2004 | 01:31 PM
PoonerElRay's Avatar
2017 GLA 250 4Matic
Matching C7 Pedals
Dealer just called and told me my order has arrived - matching gas, brake, and e-brake pedals w/ circular studs. Can't wait to pick them up!
Old Feb 10, 2004 | 02:33 PM
JimB's Avatar
2000 ML320/'03 C320WZ
Once you picked them up, care to share the parts # of the pieces
Thanks,
Jim
Old Feb 11, 2004 | 11:49 AM
2017 GLA 250 4Matic
Gas 170 300 00 04
Brake 170 290 01 82
Ebrake 203 430 00 84
Old Feb 11, 2004 | 11:57 AM
eBalita Editor's Avatar
Black c 230 Kompressor Sport Sedan
pedals - how much
how much are they?
they do require drilling?
Old Feb 11, 2004 | 12:01 PM
2017 GLA 250 4Matic
Approx. US$45 and doesn't require drilling. Do a search for Antonio or PM him. He's got the install instructions.
Old Feb 11, 2004 | 12:04 PM
thank you!
Old Feb 11, 2004 | 12:55 PM
JimB's Avatar
Thanks a lot Big Sheesh
Old Feb 11, 2004 | 12:58 PM
bagwell's Avatar
From: Houston,TX-moving to The Woodlands,TX SOON!!!
Toyota Tacoma & Lexus IS250
I put these on about a year ago....they look great and fairly easy to put on...the gas pedal is a little tricky but...looks awesome
Old Feb 11, 2004 | 01:06 PM
2017 GLA 250 4Matic
I think the gas pedal can go into the housing fairly easy with some lube/soap
Old Feb 11, 2004 | 04:38 PM
Mark08859's Avatar
2008 C300 Sport
Do you know if the e-brake can be ordered by itself? Already have the clutch, brake, and gas pedals as they came with the car.
Old Feb 11, 2004 | 04:57 PM
2017 GLA 250 4Matic
yes, order by part number.
Old Feb 11, 2004 | 05:24 PM
JimB's Avatar
Bagwell
do you have any pics you can share? Thanks
Big Sheesh...you have auto tranny,... correct?
Old Feb 11, 2004 | 05:49 PM
2017 GLA 250 4Matic
Re: Bagwell
That's what my signature says. I'll post pictures when I get them. I was too lazy to go to the dealer last night.
Old Feb 13, 2004 | 02:58 PM
nexus6's Avatar
From: Somewhere between the gutter and the stars...
C230K Sedan
I installed my C7 pedals for a manual. I didn't require drilling or anything. All pads, except gas, were slip on replacements. To get my gas pedal sorted out, I had to do the following:
Feel towards the top of the pedal assembly, and you'll find a joint where it's pinned into the lever arm itself. Pop out that black plastic pin by compressing the end of the pin on the right hand side and pushing it out to the left. Make sure you check that you did not damage the pin. If you did, go get a new one. You really don't want this to come loose when you are driving. Very bad...
Pull the pedal aasembly towards you and gently pull off the rubber pedal at the edges. This will then leave a 'strap' like bit holding on the assembly. There is no need to cut this, as some may have recommended. Put some lube between this rubber bit and the pedal with your finger (Did your mother ever tell you that you have a dirty mind?). Now pull it up and it should slide off with minimal effort.
Lube the same 'strap' area on the new C7 pedal and slide it back done. Once don, then pull the edges of the pedal cover around and back onto the assembly. take the assembly and put it back onto the lever arm and line up the holes. Pop the pin back in from the left to the right.
Test the pedal by trying to move it sideways. If it doesn't then test back and forth. once done, you're good to go!
Old Apr 7, 2004 | 03:58 PM
cruznlv's Avatar
2002 c230 sport coupe
nexus6, do you have the part# to the clutch pedal? I also have a manual. Thanks.
