2003 C240 Transmission slips
Now 2015....car goes into neutral mode (rpm accelerates but no transmission) after sudden acceleration or shifting. Current fault code is P2500.
The ABS, ESP and SRS lights are also on.
When the xmission slips occurred, engine light was on...it also occurs when the engine light was off. Car is running fine now after the mech cleared the codes......the two ABS speed sensor codes were also registered.
IN ALL CASES, switching the car on and off, fixed the neutral mode problem.
At the time of the neutral mode, you cannot shift (using the tiptronic) and the car is actually like it is in neutral...rpm races but no power....scary.
I need to have the rpm ABS speed sensors replaced on both front wheels...this is the only solid evidence that MAY contribute to the problem....
Other possibilities:
a) xmission fluid...assume OK
b) contaminated connector harness ...assume OK
c) brake light Switch ......
d) ABS speed sensors......
e) ruled out shifter - no code
f) ruled out mass flow air sensor - no code
Comments.....thx!
Dr Ash
Is there a specific code for the rpm sensors.....thx for your responses.
As more info:
.........the car was with my mechanic for several days last week and he did not notice anything of the xmission slipping that I reported. So I visited him and we went on a test drive. When I was driving I noticed the car was in some form of a limp mode....pressed down on the gas with no or sluggish response....he could not believe it so we changed seats and he observed it as well....car would accelerate slowly even after gas applied on the highway. Then after driving it hard shifting and after sudden brake and acceleration..... the original symptom that I took it to him for happened...the car slipped into a neutral mode.....no response from the transmission rpm OK when the gas was applied....we pulled over and we turned the car on and off and transmission recovered. Back to the shop he pulled his SDS scanner and checked a few things and the sluggish response all went away after another test drive. He also plugged in the smaller OBDII scanner to verify faults..... The only thing is that it the car revs at 15K-20K on idle & N. He needs to reset the idle...all else is fine. I have driven the car for the past two days not hard but it is driving like a charm and no slipping except the high idle. Not convinced the problem is resolved....Dr Ash
hange neither can I get the tiptronic to change gears.......means that the car is not in limp mode but in neutral since when this happens you hit the gas and the rmp ramps up...like in N.
Dr Ash
