higher mAh/Ah than 100Ah batterys for the w203?
Are there higher Ah capacity batterys that will fit into the space for 2004 c200 k.
Mine is 100 but just curious if theres a greater capacity upgrade available.
Also, which battery do you recomend buying as a replacement.....ive noticed BOSCH make and other parts for the car....ive also seen another brand......
Your thoughts
Danke
You have got fantastic life out of this battery but you really should change it.
Leave the head lights and blower on for 10 minutes then try to start.
Your alternator will thank you and you will probably pick up some fuel mileage.
Just Sayin
MY '06 HAD THE ORIGINAL MB 100AH BATTERY IN IT UNTIL TOMORROW. I'M GONNA INSTALL THAT GROUP 49 AC DELCO AGM BATTERY AND SEE HOW THAT GOES.
Just Sayin
If you got 11 years from this battery then you should contact the manufacturer for another. If batteries lasted this long the industry would be in shambles.
As I stated you have had good luck, so far. Winter is close, do you like to gamble also.
Its guys like u that make me laugh when they tell you the "car is well looked after ".
But thanks for the kid comment its been many years since I got that reply.
might not be a bad idea to keep a jump box in your car till you get a new battery...and maybe after that also.
