2006 C280 4Matic - P2188 & P2190
Old Oct 24, 2015 | 10:59 AM
srticalion's Avatar
2006 C280 4Matic
I just purchased a 2006 C280 4Matic and the P2188 & P2190 codes are coming up.
My thought is to change the MAF sensor. Am I going down the right path? If so, should I purchase Bosch?
Any insights would be greatly appreciated.
Side note: Prior to these codes coming up I changed the spark plugs, coil packs and air filters.
Thanks in advance!
Old Oct 26, 2015 | 09:50 PM
Holmes5518's Avatar
2016 C450
Originally Posted by Plutoe
I think you are wasting everyones time----there are no MB P faults with the numbers you provided for your engine---what that typically means is that the driver is using the girlfriends scanner--that's great for fooling around, but to really identify the problems find someone with MB DAS and get the correct diagnosis.
Additionally remember there have been a number of improvements in MAF's for you car therefore on the slight chance that there is a problem with the MAF get your part number and accept no substitutes, because if not you will be back!!
Exactly what this guy said.
Since you took the airbox off, check to make sure it's sealed around the MAF and/or you didn't dislodge the maf from the throttle body.
