HELP! Shifter Problem
Old Oct 27, 2015 | 09:28 PM
victoroy's Avatar
2003 c320 Classic
Hi guys , im new in this forum asking for help , my Mercedes Benz C320 Classic 2003 got a problem in the shifter , it stucks , i cant move it passing the N , i just can select D and N when i try to move it to parking or reverse it stucks and dont let me do that , i got a used shifter from a c200 kompresor 2003 mercedes , like i see it matches the part number , but the other number located just next to the part No dont not match for 4 numbers only , will it work ?
here is the two pices numbers that i locate outside the shifter
Original (Broke):
A 2032676024 Q 03
02 265 0674 1 10972
New:
A 2032676024 Q 03
02 265 0235 1 10972
Will the new one fit my car and work ? if not , what can i do , my local mercedes dealer is just crap , they took like 4 hours just to remove the cover to get out the shifter and brreaking all the clips
Old Oct 28, 2015 | 02:50 PM
victoroy's Avatar
2003 c320 Classic
Originally Posted by Plutoe
The two shifters with the same A part numbers are the same, repeat the same and will fit your car!!
WTF knows what the second set of numbers are\mean---they are not part numbers!!
The guy at my mercedes dealer says that it will not fit because the last number is the computer inside the shifter , something like that
