Error Codes on Kompressor, need HELP PLEASE
Old Oct 28, 2015 | 02:31 AM
Bearded's Avatar
Kompressor w203 c200
I have a Kompressor w203 c200 2003 and the CEL (Check Engine Light) is on and whenever I am stopped at while in drive the car begins to shake , little by little it will go worse until it finally falls into limp mode.
If I turn off the car and back on the car runs fine again, or if I leave the car in N rather than D while stopped the car doesn't shake. I scanned the error codes and this is what I received:
P0304 cylinder 4 misfire
P0313 misfire with low fuel
P0301 cylinder 1 misfire
P0238 supercharger boost sensor a circuit high
P0172 system too rich bank 1
P0101 mass or volume air flow a circuit range/performance
Does anyone have an idea what it could be? I think it might be an issue with the timing chain but im not sure.
Any input will be deeply appreciated .
