Question regarding redesigned C...
Why is it that the redesigned C55 has a 5 speed automatic when all the new SLK55 has the seven speed automatic?
Furthermore, why is it that the C350 is nonexistent while the SLK350 is available as well as the CLS350 and the ML350?
Mercedes' logic seems very strange to me. If anyone has any answers I would appreciate it. Comments are welcome. Thanks for listening.
I wouldn't call the C a redesign just cuz they fixed up the INTERIOR...outside sheetmetal is completely unchanged.
Not sure about the trannys but the SLK will be an all-new car. So perhaps it was was designed into the SLK and not the C. As for the engines, the SLK 350 will be the first MB to get the new 4 vavle 3.5 motor. The ML350 is the old design 3 valve motor and is actually a 3.7 liter. According to most internet sources, the CLS will not be out for a little while. So, only the SLK will have the real 3.5 motor.
you can't really tell if a car has 7 speed inless you get in and start her up and check. otherwise if you can tell the difference between an 03 e500 and an 04 e500
