What's this coolant pipe/hose called?
Old Jan 2, 2016 | 09:46 PM
silvermamba's Avatar
2005 C230
My coolant has been leaking and i think it's coming from this hose in the picture. Does anyone know what it's called and how to take it out?
Old Jan 4, 2016 | 10:51 AM
RWDlifer's Avatar
2005 C230K SS
It's a coolant line to the oil cooler. Note that there is a rubber hose (#26) clamped to a plastic pipe (#70), both are the prone to leaking. The plastic pipe is a pricey part. To replace either or both, you have to remove the airbox, intake manifold and *maybe* the oil cooler itself.
#26 hose part number 271 203 0182
#70 water line part number 271 200 1352
Attached Thumbnails What's this coolant pipe/hose called?-untitled.png
Old Jan 6, 2016 | 01:05 PM
slammer111's Avatar
2003 C230K Coupe Orion Blue
The hose is just held in place by 2 clamps. Maybe try tightening them first, or inspecting the hose for damage? To do so, just unscrew that hose clamp and the hose wiggles right out. Any cracks or holes should be obvious.
My plastic pipe cracked on the other end (where it goes into the engine block). The symptom was a slow weep. Take a look at this DIY thread. If it's the plastic pipe, it can be replaced on the spot (just 1 bolt), if your forearms aren't too thick to reach between the engine and firewall.
Old Jan 6, 2016 | 04:28 PM
RWDlifer's Avatar
2005 C230K SS
I replaced mine, couldn't get back there without removing the air box...I guess it's doable with skinny fingers..
