Door lock question
Old Jan 3, 2016 | 04:22 PM
03C230's Avatar
2003 C230 kompressor
Door lock question
Came out to the car today, went to unlock it and the drivers door lock gave like a rattling noise and didn't unlock, finally after hitting the fob button a few times it unlocked. Now whenever I try to lock or unlock, it moves the stem up and down a few times and doesn't want to lock or unlock unless I hit the button a few times, what's going on here? What do I need to replace?
Thanks in advance!
Ian
Old Jan 3, 2016 | 05:21 PM
03C230's Avatar
Originally Posted by Plutoe
The door lock is broken---remove the door panel and replace!!!
Appreciate it! Will check it out Friday on my day off!
Old Jan 3, 2016 | 08:35 PM
VVF's Avatar
VVF
2005 C230K(sold), Mk7 Jetta
Afaik you'll need to remove the airbag in the door to get easier access to the lock assy. Search for "door lock pogo stick" or similar. E.g. https://mbworld.org/forums/c32-amg-c...l-removal.html
Upd, This thread is more useful: https://mbworld.org/forums/c-class-w...ogo-fix-2.html
Old Jan 5, 2016 | 02:23 PM
zpbarnett's Avatar
2003 C240 4Matic Wagon
Pogo Lock Fix
This happened on my 2003 C240 Wagon a couple of years ago. You be able to repair it with some inexpensive lock springs. The full lock is assembly can be rather expensive.
Check out this repair thread:
https://mbworld.org/forums/c-class-w...ml#post6637689
Good Luck,
zpbarnett
Old Jan 5, 2016 | 04:34 PM
03C230's Avatar
Awesome thanks for the info! I'm gonna have the shop that normally does my repairs look into it, they said about $400 to fix it
Good Luck,
zpbarnett
