OK new problem!
Old Jan 18, 2016 | 03:34 PM
jim1966's Avatar
2003 c240 4matic station wagon
OK new problem!
My c240 key wasn't turning now does! (who knows why)drove car home ran ok. Started car in garage just to see if key would turn after starting when I put it in gear it chugs a couple times then stalls. Ive tried starting it letting it warm up and still stalls when i put it in gear. I sometimes get a battery/alternator message when it stalls but not every time. I checked battery voltage in car, car said 12.6 and 14.4 running. The battery is 1 1/2 years old and alternator about same. Any ideas before i take it to a mechanic?
Old Jan 18, 2016 | 04:54 PM
Cruel-Merc's Avatar
2009 C350
If your getting the battery/alternator msg then the alternator is the issue or the voltage regulator which was in my case.
Old Jan 18, 2016 | 04:59 PM
jim1966's Avatar
I don't get message every time (but most) and goes out after car stalls.
Old Jan 18, 2016 | 05:03 PM
Cruel-Merc's Avatar
2009 C350
Yeah same happened here until one time i was on the highway and my car electronics just shut down and was stuck in first gear then i got the battery/alternator message. Checked the alternator and it gave normal voltage but i didn't buy it i knew something was wrong with the alternator so i took it off and first thing i did i replaced the voltage regulator and the problem went away saved me couple of hundred $. That was around 3 yrs ago.
Old Jan 18, 2016 | 05:08 PM
jim1966's Avatar
Would voltage read normal on screen in car? like 12.2 and 14.4 when running and still be bad?
