Annoying noise from AC?
First it started doing a few ticks only when starting up the car. Now it's all insane going on for a few minutes after starting up, while driving.
I tried searching the forums for this, and it seems to be a complicated and expensive fix? Or am I wrong?¨
Could anyone tell me what this is? I'll upload a video.
Thanks in advance
View My Video
Read this entire thread: https://mbworld.org/forums/c-class-w...g-hissing.html
Star diagnostics can pinpoint which one of the 6 is broken, requires usually dealer visit. Cheap scanners cant show this. To fix it you need to tear entire dash open depending which motor/link it is
It also depends which motor/link is broken, some are easier to get hold of.
In the end I bought a few used motors for a tenner + one brand new, link pack from my indy and they changed them in around 4 hours @ $75/h
There are ways to do it yourself, e.g you get constant heat to footwell no matter what settings the AC has. Then just figure out which motor can cause this. I had this heat-in-the-footwell problem, but STAR also pointed out another motor to be dead which I was unaware of.
DIY guys usually tear the entire dash, run the system and are physically able to see the broken ones. Massive labor required for this causes the dealer prices to skyrocket so DIY is alternative if you are brave
