Popular torque
Old Mar 7, 2016 | 06:21 PM
danev6972's Avatar
2003 C240
Popular torque
As I've noticed, some engines have different ranges of spark plug torque settings. M111 is 25-30 ft/lb. or some here with M271 is torqued to 28nm.
What is your M112 spark plug torque setting (15-22 ft/lb.)?
Old Mar 8, 2016 | 07:23 PM
danev6972's Avatar
2003 C240
Originally Posted by Plutoe
Whats the VIN??
WDBRF61J43F313083
Haynes manual says 18.5 ft/lb. My torque wrench has a minimum of 20 ft/lb. Not sure if 20 ft/lb. is too much or not.
Thank you sir.
Old Mar 9, 2016 | 05:57 PM
danev6972's Avatar
2003 C240
On your 112.912 the spark plug torque is 28Nm
Thank you x 10. Appreciate your time. At least I don't have to spend anymore for tools.
Old May 14, 2016 | 05:33 PM
quip11's Avatar
2001 ml320, 2002 c240
Hi. I'll be changing plugs on my 2 M112 as well. Will it be the same torque specs as well?
WDBRF61J02F263572
4JGAB54E91A238941
Thanks!
Old May 14, 2016 | 11:39 PM
Bearded's Avatar
Kompressor w203 c200
Where do you go to search details about your car using your vin?
