W203 C280 4Matic Front caliper torque specs
W203 & W204 3.0L 4matics & MR2 Supercharger
Doing the front pads tomorrow on my 07' C280 4matic, saw Glyn's TQ spec thread here
https://mbworld.org/forums/c-class-w...cs-brakes.html
but I didn't see a Front caliper to caliper mounting bracket value listed, the listing of 85 ft/lbs for the [caliper mounting bracket to steering knuckle] seems to much for the 12mm bolt that holds the caliper to that bracket.
NP
NP
Regardless of what was previously posted and based upon WIS your 203-brake caliper to steering knuckle torque is 115 NM and not 85Nm and the wear pad sensor is 8Nm and the guide pin is 25Nm--------if you are talking about the F and R disc locking bolt--that is 10Nm------what are you trying to do!!
Uggggg, need new rotors also (and more new pads) outer 1/2 inch of current rotor is rusted so they need to be replaced and the new set of pads I put on will be toast by the time I get the new rotors.....
NO
$70 bucks down the drain.
NO
