Maximum # of Smart Keys?
Old Mar 31, 2002 | 11:04 AM
Mercedes101's Avatar
C240
I recently acquired a year old C240. The previous owner had some trouble with the bad keys but they were taken care of under warranty - only problem is that the car came with one smart key. When i called the dealer to order a spare they informed me that all 8 keys were made and that they could not make any more - probably due to all the repairs that had been made to the system. So, anybody know how i can solve this problem? given the nature of the Smart Key i feel very uncomfortable having only one key given the failure rates out there and that i would have to replace a lot of parts of the car to get a whole new system. Can Mercedes make an exception to this rule given the well documented problems with Smart Keys? So far everything works great but im getting nervous!
Old Mar 31, 2002 | 11:07 AM
Fuzzo's Avatar
I didnt know there was a limit to the number of keys that could be made.... did you ask the dealer what happens if the key that you have right now doesn't work... are they going to tell you that you are SOL?
have you asked the previous owner if they have the other key??
Old Mar 31, 2002 | 11:15 AM
C240
unfortunately i don't know the previous owner and don't have a way to get in touch with him. The Mercedes dealer i tried to purchase the spare said something about having to put in a whole new system that operates the smart keys and control modules (anybody know what that is and how much it would cost?). This would be a drastic last step - I want to gather some information and then approach Mercedes about making a new key since the original problems with the smart key required all the replacements to be made.
Old Mar 31, 2002 | 11:19 AM
mbtech208's Avatar
1997 Toyota Tacoma 4x4
There are 8 different SmartKeys available for your car, along with three duplicates of each key, for a grand total of 24 different possible keys. Once all 24 keys have been used, you will need a new Electronic Ignition Switch. I have yet to see a customer go through all 24 keys. When your car is new, it is supplied with Keys number One, Two, and Three. One and Two are the main keys, Three is the emergency "valet" key.
Old Mar 31, 2002 | 11:31 AM
C240
MBTech, so given what the dealer told me i can't have a "new" key made but it sounds like I should be able to have a "duplicate" of my current key made. Is that correct?
Thanks - this is the kind of info i don't get from Mercedes!
Old Mar 31, 2002 | 11:33 AM
C240
Is the mechanical emergency "valet" key considered a Smart Key - my understanding is that the car is supplied with Keys 1 and 2 only?
Old Mar 31, 2002 | 11:38 AM
mbtech208's Avatar
Since all 8 original keys have apparently been used (something I have yet to see), you can start with the first set of duplicate keys. I'd order Duplicate key number One.
And yes, the emergency key is a SmartKey too, it just doesn't have the remote entry buttons or the panic button. When the car is new, the emergency key is key number Three.
Old Mar 31, 2002 | 12:37 PM
TimmyC230boy's Avatar
From: Sitting behind thing freakin desk of mine. Dreaming I was playing my Taylors, and driving my Benz. Long Live The VRAA!!!!!!
C230 Sports Coupe
When I got my new C230 it only can with 2 keys. No valet key to my knowledge, wasi supposed to get one?
Old Mar 31, 2002 | 12:52 PM
Deb's Avatar
Deb
2002 C230K Sport Coupe
TimmyC230Boy,
Check your owner's manual under keys. The valet keys are cleverly locked into the smart keys.
Point of clarification: I referred to the mechanical keys as "valet" keys because of the terminology used above "emergency, mechanical, valet...." Apparently the C230K comes only with two smart keys, each with a mechanical key inserted. At least that is what I got.
Deb
Old Mar 31, 2002 | 12:59 PM
mbtech208's Avatar
Actually, those are just the mechanical keys. You should have gotten a third SmartKey which is thinner than the normal SmartKey, and is missing the buttons for remote entry. This is your valet/emergency key.
Old Mar 31, 2002 | 01:15 PM
Lynn's Avatar
I only received two keys.
Old Mar 31, 2002 | 01:25 PM
young's Avatar
GLB 250 4matic
i think they changed it for 2002 (sedans too). you used to get 3 keys. now you get 2.
Old Mar 31, 2002 | 02:20 PM
Cullen's Avatar
I'm lucky.. my car accidentally came with 3 full-size normal keys. The salesman said it was a mistake, but of course let me have them all anyway. No valet key, which i think is the normal now.
Old Mar 31, 2002 | 02:25 PM
awiner's Avatar
2003 CL55 AMG
I got 3 keys as well. 2 normal smart keys and a 3rd valet key. Maybe they did change this in 2002. I'll ask and find out.
Old Mar 31, 2002 | 02:35 PM
patrick's Avatar
two or three keys?
In Europe, from dec. 2000 on, cars are delivered with only two "smart" keys, no emergency key.
Old Mar 31, 2002 | 04:09 PM
MB-BOB's Avatar
Admin Alumni
See Garage
mbtech, my understanding is that the electronic emergency key was supplied with 2001 models, but is not supplied with 2002 sedans or coupes.
Old Mar 31, 2002 | 09:21 PM
mbtech208's Avatar
Huh, I'll be damned.
Old Apr 1, 2002 | 11:41 AM
revstriker's Avatar
K Car
I too only have the 2 smart keys on my MY 2002. I smell a cost saving measure!!
Old May 10, 2007 | 05:40 AM
jewllzs's Avatar
Re: Smart Keys
I have a 2001 CLK 320. Just recently my key would not turn. I drove myself crazy trying to figure out why.
I didn't know you could only get 8 keys issued before you would have to have the entire EIS/Computer replaced. Estimated cost $4000.00
I found an interesting website http://www.fazmiclaw.com/mbzkey.html
Check this out if you have gotton the maximum replacement keys.
This is a Law Firm investigating ELectronic Smart Keys, once you've reached the replacement limits Mercedes will have to replace your control/computer unit which is expensive.
I hope this helps the fellow who found out the maximum was reached for his Mercedes replacement keys.
Old May 10, 2007 | 06:23 AM
BavarianPride's Avatar
2013 E350
[QUOTE=jewllzs;
I hope this helps the fellow who found out the maximum was reached for his Mercedes replacement keys.[/QUOTE]
If this fellow hasn't been helped yet, he's in trouble. This thread is only
about 5 years old. LOL
