brake guru?
Old Mar 6, 2004 | 01:48 PM
c230_2k2's Avatar
Alabaster White C230K Grey Int. and 2003 C32 pewter/charcoal gray
brake guru?
Is this normal on our brakes?
Im completely stop and after a minute my foot on the brake pedal just starts to go down slwoly towards the floor. is this normal? is there something wrong?
Old Mar 6, 2004 | 02:48 PM
jlm003's Avatar
2009 Porsche 911 Carrera S
There’s definitely something wrong!!! Check your brake reservoir fluid level for it sounds that it’s very, very low and/or you have air in your brake lines and they need to be bled or your brake pump/booster might be defective. Also look under the car in the vicinity of the wheels and see if you can notice any wet or oily areas. Same goes for the area in your garage where you usually park.
Bottom line: Take it to your dealer ASAP if it's under warranty or to a respectable brake shop if not but by no means continue to drive around with this defect.
Old Mar 6, 2004 | 08:52 PM
IOBH's Avatar
2004 230K
Sounds like the seals on the master cylinder are passing so even if the fluid level is full this will cause the pedal to do that. Get it fixed quick as you might lose braking when you need it the most.
levelr123g's Avatar
no nothing is probably wrong, if your car stops ok, and the fluid is not low then i wouldnt worry.
