Kleeman header buzzing
Old May 31, 2016 | 03:03 PM
LexBrett2's Avatar
2007 Mercedes E550
Hey guys, had Kleeman headers installed and a buzzing/kazoo sound is coming from the tail of the car. Thinking it was the muffler, I changed to an aftermarket muffler but there annoying metallic sound continues. Had several mechanics indicate this is normal due to the higher airflow, albeit the metallic sound. I even stood under my car while mechanic revved engine and the metallic sound occurred from muffler. I repeat- I thought it was the muffler but I replaced the muffler and sound still occurs. Could the high airflow really cause this metallic sound?? Note there are no leaks and no loose heat shields!
So frustrating!
Old May 31, 2016 | 07:00 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Is there a resonator? You sure there's no leaks?
There's some video for a bmw 'rasp elimintor' ,
check it out and see if that approximates what you
are experiencing.
I put a resonator on after installing header to reduce that rasp.
See my sig.
Alas the header and the AR20 are gone now.
AR20 cracked and I had it removed, and header removed for smog.
Old Jun 6, 2016 | 10:02 PM
LexBrett2's Avatar
2007 Mercedes E550
are experiencing.
See my sig.
Did the reasonator help a lot? What reasonator model did you use? My guy at Midas suggested the same thing, but I worry about increasing back pressure
