HOSE SIZE??
2003 C240
HOSE SIZE??
Hey all,
Changed the MAP, solenoid, air pump. Still getting P0410 air/eva. The vacuum hoses is wearing out and cruddy & needs a definite change. Can anyone tell me the size of the vacuum hose pictured? 3.5mm maybe? On #2 where does that hose go anyway? Thanks.....
Looks like similar to this one:
"Vacuum hoses on top the valve cover"
A1179970982 - by the meter
See if it helps you find the correct hose.
2003 C240
Not sure man... I was kinda searching for a vacuum hose that connected to the EGR valve,
and that was what I found, it looked like most of the hoses on some diagram were the same PN for my engine if I remember correctly.
found this post. did you find out what size the vacuum hoses are? I need to replace the hose that you labeled as #3.
And since one hose aging out usually means others are on their way.. is there a guide anyone has to all the vacuum hoses on the m112 engine? Its time for me to check them all and replace most. 210,000 miles and 15 years - so to be expected.
