Retrofit of Bose sound system
w203 C-class
Good day to you all. Out of curiosity I wanted to check what kind of speaker I have on my rear board (sedan w203 2005). So after long fight I menage to open the cushions and to my surprise I discovered that there is only foam and no speaker what so ever. I found out that in my version (classic) the low range speaker was installed only if somebody payed additionally for it and in avangarde version it was included in as a standard.
To the point now. I would like to buy bose speakers from AMG version and I know for a fact that there is low range speaker included to the set (see the picture in the link)
http://i.ebayimg.com/00/s/MTIwMFgxNj...ZWV9Vz/$_1.JPG
First of all can I actually physically cut the foam and install the speaker on my rear board, if yes how do I connect it to the sound system? I don't see any cables which would allow to connect it (I guess if they didn't include speaker they didn't install harness as well).
I am complete rookie if it comes to car electric/electronic, so I would need some extensive and dumb proof explanation if one will show up.
Cheers!
Cheers!
w203 C-class
There is a DIY tutorial well written up that replaces the Speakers in the car
Here is a link Speaker Upgrade
I don't know about the fit on the parcel shelf but I would first look at the amp and see if it is the same as the one with the extra sub.
![](https://mbworld.org/forums/images/ranks/veteran_army.png)
Its possible, you will need many parts beyond the speakers you show. You need the H/K amp, fiber optics, a new wiring harness that starts at the rear amp and goes to all of the speakers, you will need to remove all of your seats, carpet and rear parcel shelf to route the harness correctly. You need to cut the foam in the parcel shelf or get new foam for the 810 option (H/K audio). In order to have dynamic volume adjustment, you will also need to route another harness and install a microphone in the head liner. In addition, I think you are correct that the speakers you show in your picture are for the Bose system, you need the ones for Harman Kardon, they are blue.
