Preferred Cylinder head version for 2005 C230K built before December 2014?
Old Sep 13, 2016 | 01:34 PM
RedGray's Avatar
2005 C230K Sport Coupe
Hi!
I need to replace the head gasket on my 2005 C230K coupe with an M271 engine and supercharger. The car and engine were built before December 2014.
I also want a new head.
From online, it seems like the cylinder head with valves for my car is listed as A2710107001.
But, I see that there are also listed newer A2710107101, A2710107201 cylinder heads.
Is there a benefit to going with one of the newer cylinder heads?
Will they fit?
A2710107001 CYLINDER HEAD WITH VALVES
To Engine: 30677490 => To Date: 12/08/2005
CodeBInformation - Code information: -924-M012
[M012] 19990728 ENGINE WITH GASOLINE DIRECT INJECTION
A2710107101 CYLINDER HEAD WITH VALVES
To Engine: 30853899 => To Date: 17/11/2006
Except model year: P 30903258309112653101939731119306
Except model year: M30806378308098683082190330839308
From Engine: 30677491 => From Date: 13/08/2005
A2710107201 CYLINDER HEAD WITH VALVES
[114] From Engine: 30853900 => From Date: 18/11/2006 Except model year: P 30806378308098683082190330839308
From Engine: 30853900 => From Date: 18/11/2006 Except model year: M30903258309112653101939731119306
Fwiw...
I know I can get the head built. However, it's not worth my time or the risk. Unless someone is a professional engine builder, then there's no way to really know how good of a job the shop does on any shop work. One of my degrees is in Mechanical Engineering (also Computer, and Electrical. Fwiw, the tri-degree is not that uncommon), so I'm familiar with shop work, tolerances, etc. I've also fully rebuilt, by myself, 6+ engines. And, I've been and engineer and working on cars for over 20 years.
I can get a new head with valves from Germany for ~~$1,500 (includes shipping). Imho, that's a small delta cost verses a rebuilt head. Especially when compared to the total amount I'm spending on the maintenance/restoration replacements (~$4K+ - MB Timing chain, new Bosch alternator, Kleemann header/cat, Magnaflow secondary cat, primary & secondary O2 sensors, fuel injectors, MB cam/crank sensors, MB water pump, tensioner, belt, $12 hose and other hoses, spark plugs & new filters, supercharger pulley, HID headlights, etc, etc,).
The brakes, rims, and tires come next year.
Thanks In Advance!
Old Sep 13, 2016 | 07:57 PM
RedGray's Avatar
Originally Posted by Plutoe
If you want correct information---post your VIN
My VIN is:
WDBRN40J55A755640
The car has ~82,000 miles, and has never been driven in the winter.
Other than the misfire on Cylinder#3, and the bad head and gasket, the car is in very good shape. It'll be in great shape after I'm done with it.
Ident. number (FIN) WDB2037401A755640
VIN WDBRN40J55A755640
Baumuster 203740
Sales name C230 KOMPRESSOR
Order number 0 5 704 39967 (Destination: USA)
Delivery date 23 11 2004
PAINT 1590U FIRE OPAL RED - UNILAC
Interior color 231A LEATHER - BLACK/ANTHRACITE
Engine 271948 30 528454
Gearbox 722695 05 810755
General data for model code 203740
203740 CLC-class C203 C230K 271.948 722.695 3
203740 CLC-class C203 C230K 271.948 716.605 716.628 716.631 3
SA codes
055 YOM 14/2
212B OP. INSTRUCT. AND MAINT. BOOKLET-ENGL. FOR USA
221B SIGN COOLANT/REFUELING - ENGLISH
230A LEATHER
232 GARAGE DOOR OPENER WITH 284 - 390 MHZ FREQUE
249 INSIDE AND OUTSIDE MIRROR AUTOMATIC DIMMING
264 LICENSE PLATE ATTACHMENT AMERICA
275 MEMORY PACKAGE (DRIVER SEAT, STRG. COL., MIRROR)
284B AIRBAG LABEL - ENGLISH FOR USA
287 THROUGH-LOADING FEATURE
293 SIDEBAG IN REAR LEFT AND RIGHT
301 ASHTRAY PACKAGE
309 CUP HOLDER
30N STEUERCODE WERK SINDELFINGEN/GRAZ
345 RAIN SENSOR
387 MOBILE PRE.-INSTALLATION (MTUS) USA / CANADA
413 PANORAMIC SLIDING SUNROOF/GLASS SUNROOF
423 5-SPEED AUTOMATIC TRANSMISSION
461 INSTRUMENT WITH MILES IND. AND ENGLISH LEGEND
494 U.S. VERSION
524 PRODUCT PROT. F.PAINT - TRANSPORT VEH.PRESERVATION
531 COMAND APS
535 AUDIO 20 CD RADIO, USA
551 ANTI4THEFT/ANTI-BREAK-IN WARNING SYSTEM
573 CHILD SEAT MOUNTING, ISOFIX IN REAR
580 AIR CONDITIONER
634 DELETION - FIRST AID KIT
636 DELETION - WARNING TRIANGLE
668 PRODUCT PROT.F.TRANSPORT VEH. W/ TIE-DOWN HOOKS
669 SPARE WHEEL / FOLDING WHEEL
673 HIGH-CAPACITY BATTERY
689 L.A. 74SPOKE DESIGN, 17 INCH WITH MIXED TIRES
704L UNITED STATES (USA)
763 RADIO REMOTE CONTROL W/ PANIC SWITCH (315 MHZ)
7XXL NORTH AND SOUTH AMERICA
805 YEAR OF MODIFICATION
819 CD CHANGER
873 SEAT HEATER FOR LEFT AND RIGHT FRONT SEATS
875 HEATED SCREEN WASH SYSTEM
949 SPORTS PACKAGE
986 IDENTIFICATION NUMBER (VIN-NO.)
989 IDENTIFICATION LABEL UNDER WINDSHIELD
F203 SERIES PRODUCTION 203
FCL COMPACT LIMOUSINE
GA AUTOMATIC TRANSMISSION
HA REAR AXLE
L LEFT-HAND STEERING
M014 ENGINE INCREASED PERFORMANCE
M18 DISPLACEMENT 1.8 LITER
M271 R44GASOLINE ENGINE M271
VL FRONT AXLE HALF, LEFT
VR FRONT AXLE HALF, RIGHT
W52 TRIM PARTS CINNAMORRA DESIGNO ANTHRACITE
AGG_VAR A 271 010 20 02
ETV_BM 27194830
ZUTEXT
Thanks In Advance!
Joe
Old Sep 14, 2016 | 12:19 PM
RedGray's Avatar
Thanks!
That helps to confirm that I have identified the correct parts.
Based on the length of production, it seems like the newer A2710107201 head may be better. However, that engine combo wasn't offered in the US. So, it's hard to get/verify the needed associated parts - like the lifters and rocker arms.
So, it seems like it is best to play it safe, and go with the same version head.
Thanks again!
Old Nov 15, 2016 | 02:09 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
What is W52 TRIM PARTS CINNAMORRA DESIGNO ANTHRACITE ?
There's only been 2 fully designo coupes around here, one yellow with gawd, yellow and black leather, in the UK, , and one in red, with red and black leather, really sweet was it Malaysia?...
So what is this piece?
