A few confusing electrical/fluid problems
As for the no start, does the starter turn? If not, it sounds like a vehicle security issue.
When did you jump the car, verses the no start condition? Very few people jump start a car properly.
i) Charge up the weak-battery for 5-10-15-30mins (depends on how low the weak-battery is).
ii) Fully disconnect your charging device/method.
iii) Start the car.
To go more in depth.....
There are three general ways to jump start a car.
1) From another car with a good battery.
2) From an AC charger.
3) From a mini-battery pack.
There are also 3 risk amount when jump starting a car:
a) The 100% correct and safe way.
b) The risky way.
c) The very risky way. :-P
Let's start with:
1) Jump starting a car from another car with a good battery.
In general:
Avoid connecting the jumper cables right to the battery.
Use the positive jumper terminal that most newer cars have.
Connect the ground to a good ground location. This can be harder to find.
1a) The 100% safe way:
With both cars off, connect the cars with battery cables. Use the jumper cable connection point on each car.
Start up the car with the good battery.
Charge up the weak-battery for 5-10-15-30mins.
Turn off the car with the good battery.
Fully disconnect the cables.
Start up the car with the weak battery.
1b) The risky way: (1A didn't work - the weak -battery is too weak, you need to get to the hospital for a surgery, an interview, a final test, etc).
Turn off the car with the good battery!!
Keep the cables connecting the two cars
*** This results in the alternator of the weak-battery car trying to charge two batteries, and with the 2nd battery connected through a "higher resistance wire".
This puts a HUGE load on the alternator of the weak-battery car. That excessive load and then the immediate disconnecting of the 2nd battery can ruin/damage many voltage regulators.
Often, the damage is "latent", and the alternator will work for a while. Eventually, the damaged junctions inside the regulator fail, resulting in a bad alternator.
1c) The HIGH risk way: Do not do this!
Keep the car with the good battery running - VERY BAD!!
Keep the cables connecting the two cars.
*** This results in the two alternators fighting each other. One or both may loose the fight.
2) Jump starting a car from from an AC charger.
In general:
With the car off, connect the AC battery charger. Use the jumper cable connection point on each car.
Turn off the AC battery charger.
Fully disconnect the charging cables.
1b) The risky way:
Keep the AC battery charger on.
Turn the the AC battery charger off.
*** This results in the alternator of the car fighting against the AC battery charger for "some period of time". Some professional battery chargers are "designed to handle this method of starting".
Imho, do not trust it. Especially if you're a dealer service only person. For my C230, that's ~$1,000 for the alternator, and ~3hours of labor at ~$200/hr.
Imho, if 1A didn't work, get a new battery!
Depending on the battery charger, the alternator may have get stressed a little or a lot. This method also adds risk of damage to both the alternator and the battery charger.
3) Jump starting a car from a mini-battery pack.
In general:
3a) The 100% safe way:
With the car off, connect the mini-battery pack's cables to the car. Use the jumper cable connection point on each car.
Fully disconnect the cables from the mini-battery pack.
1b) The risky way:
Keep the cables from the mini-battery pack connected.
This puts a huge load on the alternator of the weak-battery car. That excessive load and then the immediate disconnecting of the 2nd battery can ruin/damage many voltage regulators.
This can also damage the mini-battery pack, since many are not designed to be charged by a high-current (100+ amps!).
There are cheap voltage monitors that plug right into the cigarette lighter. Don't leave them plugged in all the time.
They are an easy way to check the voltage of the battery before you start the car, and with the car running.
Walmart, auto stores, Amazon all carry them.
An example is: ~$10
INNOVA 3721 Battery and Charging System Monitor
