Clutch Nightmare
Old Nov 1, 2016 | 10:24 AM
shiven.gopi's Avatar
2006 C180K
Clutch Nightmare
Hi All,
Hope you all well.
So of recent my C180k 2006 6 Speed Manual clutch plate has given up.
I took the car into the shop and they advised that the car required a clutch and pressure plate replacement. The dual mass flywheel was given a light skim and put into the car.
I went to the shop today to check the car out, the car has a vibration over 2500rpm. Can this be the flywheel?
Also the flywheel is a SACH part however the clutch plate that came out the car is a LUK. We replaced the clutch plate with a LUK R469mk clutch and pressure plate.
Please can you advise if replacing the flywheel will solve this vibration issue.
Thanks in advance.
