New purchase?
Old Nov 20, 2016 | 07:24 PM
ASAP RANDY's Avatar
C class
New purchase?
Hi all, I was looking to ask a group of people who actually know about these cars as to whether this would be a good choice for my next car? My current vehicle is getting old and my friend has a C class and I've driven it and liked it, but I'm concerned with the long term longevity of these cars. Nothing in particular I've heard, but should any repairs need to be done, I'd imagine they're a bit expensive. So, I'm looking at getting an 05-07 C230 Sport, they usually have over 100k miles. I might go check some out in my area, what are some key points to look for? I live in Florida so rust won't typically be an issue. Also, what's the option with the aluminum dash inserts called? Thank you guys in advance!
Old Nov 20, 2016 | 09:59 PM
LexBrett2's Avatar
2007 Mercedes E550
These are solid cars. I bought my '05 with 125k miles. Connect an obd2 sensor and make sure no codes. Feel how the car shifts. If the downshift or up shifts feel hard that's a problem. Feel the suspension. Are there are clunks or smooth? Pass these tests and you have a gem
Old Nov 21, 2016 | 11:19 AM
LILBENZ230's Avatar
2019 G70 6MT & 2022 Ford Maverick XL
Go with a 2007 if you're set on a W203. The 2005 uses a supercharged I4 prone to timing chain issues.
Old Nov 21, 2016 | 01:11 PM
LexBrett2's Avatar
2007 Mercedes E550
my 05 has been wonderful, and some prefer the I4 supercharged to the v6. On the other hand, 2 years on a used car can make quite a difference
Old Nov 21, 2016 | 03:07 PM
C230 Sport Coup's Avatar
C230 Sport Coup + 2006 W164 ML350 + 99 Ford Escort RIP
Yes, but isn't the 07 prone to balance shaft issues due the gear wearing due to soft metal?
The chain can be replaced as a maint. item.
The balance shaft requires removing and tearing the whole engine apart and cost $5K-$10K to replace.
I'd go with an low mileage '05 and plan on replacing the chain, much better on gas too.
Old Nov 21, 2016 | 07:11 PM
ASAP RANDY's Avatar
C class
I've read that running the vin and identifying the engine serial number and as long it falls above a certain number, you're in the clear for the balance shaft issue.
Old Nov 24, 2016 | 04:17 PM
LILBENZ230's Avatar
You can get an 07 that is out of the range for the balance shaft. I had an 05 that I loved and that was great all the way through the 150,000 miles I put on it. But I didn't see it as worth the risk past that - and I won't recommend it now. Replacing the chain can be done, sure, but at a huge cost (unless you DIY, but that's not for the faint of heart). The lowest quote I've seen even from an indy was in the $2,000 range.
So I'd reiterate, my recommendation for the W203 is an 07 that you can verify is beyond the range for the balance shaft.
