car not starting
it will after cranking a bit want to start slightly but that only last a couple secs then stops and just turns over freely.
no check engine light.
scanned for codes and says everything ok
changed the cam postition sensor. nothing
checked spark with inline testor have spark
checked fuel pressure it says 50-52, believe i need 60 so would that stop it from starting
checked the brake pedal switch seemed ok
thinking i might change the crank position sensor but it should give a code if bad correct
where do i look now or just head to the mercedes garage
