Is my erg valve causing my bad idle?
Old Jan 15, 2017 | 03:28 PM
LexBrett2's Avatar
2007 Mercedes E550
Chasing down causes for my bad idle, I realized that the erg valve may be the culprit. When I start the car, after a few minutes, I hear a hissing sound which I think is erg valve opening. At the same time, the idle becomes eratic. I cleaned the erg valve the best I could, but could not remove because my aftermarket headers are in the way.
anyone have any suggestions??
Old Jan 18, 2017 | 09:56 AM
slammer111's Avatar
2003 C230K Coupe Orion Blue
Check the hoses leading into the EGR (1 big one, 2 small ones) as well. During routine maintenance recently I discovered all 3 had cracked. Be sure the check the entire lengths of the hoses, including the thin one that snakes across the top of the engine and over to the intake.
Old Jan 18, 2017 | 10:26 AM
LexBrett2's Avatar
2007 Mercedes E550
Great tip sir, thank you.
I also saw a mercedessource video where they pressure tested the ERG valve.
If it doesn't hold pressure, needs to be replaced...
