pinging
Old Apr 4, 2004 | 12:04 AM
jigga619's Avatar
2002 C230
pinging
i've always used 91 octane gas and i can feel my car pinging when sitting at a light.. is this normal? if not, is it covered under warranty?
Old Apr 4, 2004 | 12:37 AM
vadim's Avatar
'19 GLC 300, '19 TM3SR+
It definitely is not normal. No matter what fuel grade, it should not ping. Take it to the dealer ASAP.
Old Apr 4, 2004 | 04:12 AM
yeloaw's Avatar
c240
What is pinging?
Old Apr 4, 2004 | 04:24 AM
vadim's Avatar
a charactristic "crunchy" sound, also referred to as "knocking". It is caused by in-cylinder detonation due to premature combustion.
All modern cars have knock sensors. When the ECU sees signals from such a sensor indicating detonation, it retards ignition timing to try and eliminate the problem.
Old Apr 4, 2004 | 02:28 PM
Mike T.'s Avatar
2005 smart cabrio; 2008 Mercedes-Benz B 200
pinging
....a.k.a. pinking in Britain....
Well I find it very hard to believe that any car at idle would ping. If it was, the engine would surely hole a piston or two shortly after it's driven off.
Pinging normally occurs under load. The electronics should compensate for any pinging and if it's extreme, I would expect the electronics to be smart enough to shut the engine down or make the car undriveable.
I would suspect a rattle of some sort.
Either way get it checked out, but if it really is pinging you should get out immediately and start walking. Otherwise you're likely to melt down your engine in short order.
Old Apr 4, 2004 | 10:46 PM
levelr123g's Avatar
your car will not ping at idle.
