07 C280 4matic coolant temp sensor screw snapped !!!
Old Mar 2, 2017 | 10:52 PM
astritmulla's Avatar
ML350 2010 - W164
Hey Guys,
2007 C280 4Matic (W203)
I was trying to replace the coolant temp sensor and the screw that holds the metal plate snapped. Do I have to use a hoist and pull up the engine in order to remove whats left of it ? Also, do I need to disconnect transmission as well ?
is there another way I can try to remove the screw without having to remove the engine/transmission? Anything will help!!!!
thanks
