2006 C280 hesitations
I recently joined the group and I've tried numerous times to find a thread that addresses an issue I've experienced with my vehicle. While exceleranting I have this hesitation almost like a misfire. While it's idling I don't have any droproblems or misfires just a steady idling. I had the fault codes printed up and I get
I've changed the cam shafts sensors, crankshaft sensor, fuel pump, fuel filter, spark plugs, nothing changes. Taken it to different mechanics and they are equally baffled. I'm at wits end trying to figure what is causing the hesitation, it also happens when I'm passing it does it almost like it's stalling, then catches then stalls continually. Please please help or any suggestions you may have to help with this issue.
Disconnect MAF (Mass Air Flow) sensor connector and see if those symptoms change while driving. Try cleaning the MAF with CRC MAF cleaner.
