2005 C230 will not turn start or turn over
My 2005 C230 K died on me going down the road. My #53 fuse (ECU Fuse) was blown.I replaced it and the blows as soon as the car is put into key position 2 and then the cooler fan goes full speed.
I’m thinking it’s a short between the Front SAM and the ECU. I was wondering if anyone has more information on this issue.
My issue turned out to be a short in the #2 coil which caused the #53 fuse to blow. The #53 fuse provides power to the ECU and the coils so once the fuse was blown the ECU lost power and that caused the Cooling Fan to run on High speed.
Did you get that taken care of yet? Sounds better than having to replace the ECU. Though we could have helped you in that department. Best of luck!
