Stuck in Neutral
c230 2006 4door sedan
car turns on, no codes.
the shifter moves normal but the car acts like it's in neutral. let's say I put it in reverse or drive and the car sits like it's in neutral. The car doesn't go anywhere, it is stuck in neutral. I can put it in park.
I've checked the fuses, again, no codes.
Any ideas on narrowing down the cause? Anyone heard of this happening?
i found the shifter bushing under the car so seems that is the culprit.
question - can you easily reach by hand and get to the shifter rod to connect/plug it back into the rod that connects to the trans??? i saw a video on youtube for this repair on a w202 and the guy (mercedes medic) says you can only reach the shifter bushing/rod area by using an extension custom tool is that correct??
really appreciate any feedback on this!!!
https://www.youtube.com/watch?v=Z99Kf-8JLHY
i am gonna put my c32 up on jacks and see if the shifter bushing is still in the shift linkage or if it degraded and broke apart. i have the part #15 in the diagram here "shifter bushing" which inserts in to the bushing that fills the circular slot in the shifter linkage. to get that plastic piece to squeeze into the shifter linkage slot i read you do need that special tool in order to get enough levergage in the narrow space to push it in... ?? gonna try it
http://www.mbpartsworld.com/showAsse...roduct=7418246
I replace the same pieces and my Transmission is in Neutral, only move the shifter not the transmission.
So do you have good news for this situation?
thanks to answer.
