Transmission..slip..leak..lurching forward upon coming to full stop.. help?
Hello All,
Any advice would be much appreciated, thank you!
I've been noticing the past 2 weeks now, that i believe may be a transmission issue, looking for some advice as to what i should do next to remedy the current situation, and or my options. Thanks for any replies in advance! cheers.
Symptoms,
I've been noticing from a cold start, rolling out of the driveway put in gear to move forward, and only between 1-2rpm that the car seems to lurch forward, like a slip or something a forward lurch of the car. I notice this only from cold starts, then drives normal, will happen once in awhile, not often when car is warm.
Noticing this symptom frequently,
upon coming to a breaking stop, almost every time, car will do the same thing. just before i'm about to reach a full stop, and from any speed fast or slow coming to a stop. Car will lurch forward, like a down shift issue or slip, and between 1000-2000rmp usually.
mercedes benz dealership,
just got my vehicle back from the dealership, i think they did a half *** diagnostic, anyway. This what their customer service advisor said on the service receipt. " Transmission has a leak in area of pan gasket. Topped up transmission fluid."
" recommend full transmission fluid and filter change $450.00 plus tax (may need possible transmission) If concern persists after transmission fluid change."
They said it was down 2 litres trans fluid, after i got the car drove it for a little bit, i noticed similar symptoms happening mentioned above. considerably not as often coming to a breaking stop, and very mild lurch forward from a cold start.
Help/Advice
Not sure what my best course of action is to take, with out spending a fortune.
Has anyone experienced a similar situation, Will a flush and trans mission fluid change and re sealing potential leak fix the issue? or will i be wasting time and money not really fixing the problem? is it just a valve sticking, where is the leak exactly coming from, just questions on my mind.
