After-mkt Navigation System
Same thing goes for ordinary radio/cd/mp3 players.
Also, most places will cut your factory wiring harness to install the radio. The companies here in the states tend not to stock the wiring harness kits. However, companies like Kenwood and Alpine probably make a wiring kit for the European standard of wiring harness that Mercedes uses (as well as Volkswagen/Audi and maybe BMW, I'm not sure). Usually those are only sold with the European versions of the receivers. However, a good shop could probably order it from the parts catalogue.
The only problem with the aftermarket one was it killed the audio controls, and telephone feature on the steering wheel.....later we were able to dial into the system and get the volume control to work though
over all...i loved it! wouldnt do anything different....and the only stock system that is worth any money is on the lexus....their's even shows backroads that mine wont.....
I don't know how different the Lexus nav is from Toyota's, but my wife has a new 2002 Camry and the nav works pretty well (although it's the first nav I've used so I have no reference to other systems).
I've heard the 2003 may have a DVD based system, but don't know if I can wait to find out.:p
no problem man! yeah, the lexus one uses the same satalite as toyota (as so i'm told
Actually, I should probably look at getting a 230 out here, Bay area in Cali. It sounds like I would get a better deal here than in FL ... more competition ... more of a market. I'm sure the cost of the trailer ride to FL would more than offset any savings though.
Don't know if I should ask ... are you a VOL?
... cause I'm a Gator!
If you are ... good luck in the SEC this year.
There should be a standard for the map database files on CD-ROM or DVD-ROM. That would make it so you could buy an updated map CD or DVD from a different company and put the disc into your unit and have it work with the new streets, freeways, etc. However, all the companies probably use different file formats.
i use to live in destin...thats why i asked...i go down there about 1-2 times every 2 months....
Can't wait to see what the install looks like. Apologies in advance if you did already post and I haven't found them.
