Oil leak after valve cover gasket replacement
Old Jul 7, 2017 | 07:15 PM
pauldgg's Avatar
2003 C320
Hello,
I just replaced leaking valve cover gasket on passenger side of my 2003 C320. I tied all bolts up to 8nm, everything looked good.
Yet after starting an engine in about 3-4 minutes I noticed oil leaking on the floor, from bottom rear side of the cover. I have not used any sealants, just gasket.
I cannot see any problems, though that side has limited visibility. Why would oil leak develop with a brand new (aftermarket) gasket? Can it be gasket failure?
Thanks.
Old Jul 7, 2017 | 08:39 PM
playfair's Avatar
S203
gasket was seated properly? bolts were tighten in order? you replaced the gasket because it was leaking? maybe there are gaps in between contact surfaces? i think flatness is the word, sorry english is not my language. there is a tool to check that. this can happen if someone in the past took the cover off while the engine was still hot
Old Jul 8, 2017 | 06:48 PM
efzauner's Avatar
2005 C240 2011 R350
hmm... odd.. I have done this job and it went well. Try removing the cover again and making sure the gasket is well sealed, not twisted etc. Did you clean/scrape both surfaces before re-assembly?
Old Jul 10, 2017 | 12:38 PM
pauldgg's Avatar
2003 C320
Apparently the gasket fell out at the rear bottom end when I was putting it in.
Reinstalled, and seems fine, other than a bunch of oil collected at the engine pan still dripping.
I strongly advise against doing this as DYI, unless you have a properly setup working environment with floor protection and very large oil drip pan - that oil spill cost me lot of time to cleanup, and some environment damage too.
On a side note: what kind of moron put RUBBER gasket in engine area with constant high temperatures? Obviously it will eventually fail. So much for "german engineering".
Old Jul 10, 2017 | 05:13 PM
efzauner's Avatar
2005 C240 2011 R350
well most do this repair quite successfully. It is not technically difficult. with most of the time being removing parts and hoses to access the cover. As for rubber... remember that valve stem seals are also rubber, as well as many other internal engine seals that are in direct contact with hot oil. So I don't think that rubber is the issue here.. But I agree.. we have been building engines for over a hundred years, why MB can't get a valve cover right is beyond me.
Old Jul 10, 2017 | 09:54 PM
FCPEuro's Avatar
Former Vendor of MBWorld
Mercedes
They typically fail when the breather passages in the top of the valve cover clog causing excess crankcase pressure. Eventually MB did get it right, the M272's in the later 203's I have yet to see those engines leak. They also switched to a sealant as a gasket on those engines.
--Kyle
Old Jul 12, 2017 | 04:30 PM
evannguyen's Avatar
1999 & 2005 C230 Kompressor
FYI, most if not all valve cover gaskets are made of the same material. I wouldn't be too quick to call all automotive engineers morons.
