Auto to Manual.
Old Jul 17, 2017 | 09:50 AM
Andrew c230's Avatar
c230
Auto to Manual.
Can you convert an automatic c230 kompressor to 6 speed and what do you need
from donor to do it ?
Old Jul 19, 2017 | 09:34 PM
junkyarddawg's Avatar
1995 E420, 1998 E300TD, 2002 CL230K 6spd, 2002 CL230K auto, 2002 CL280T VR6 Project, 2001 A6 2.7T
The swap can be done but you will need a donor car or full swap kit. Parts needed are, 716.6xx manual transmission with throw out cylinder and complete shifter assembly with boot and knob, MB dual mass flywheel with bolts and pilot bearing, clutch disc, pressure plate, clutch/brake pedal cluster with hydraulic lines, cylinder and switches, front half of drive shaft or assembly, and these are just the main hard parts. You will still have to version code the engine control module and fabricate some wiring to make it work. It will be easier to sell your automatic car and find a decent 6 speed car if that's what you want.
